Home » Sponsored » Pi Speakers » Theatre 4 Questions
Re: You've got mail! [message #50298 is a reply to message #50297] Wed, 22 November 2006 07:52 Go to previous messageGo to previous message
Doug is currently offline  Doug
Sounds great. Please let me know what you think of the mid horns after you do some more testing. I was leaning towards buying the 4 theater with the mid horns.
What sort of internal bracing did you use for your 4's? Does the mid horn just sit on top of the main box(not attached)? Did you have to buy your own port tube for the 4's or did you simply cut a hole and not use a port tube? Did you use MDF for the box? I was considering using a combination of baltic birch and MDF.
Any help would be greatly appreciated.
Thanks,
Doug
Previous Topic: A "Slim" sub based on four JBL 2226s
Next Topic: Tweeters and different woofers?
Current Time: Thu Nov 19 07:00:57 CST 2026
