Home » Sponsored » Pi Speakers » 8 Pi Question ?
Re: 8 Pi Question ? [message #50286 is a reply to message #50282] Tue, 21 November 2006 11:24 Go to previous messageGo to previous message
You can make the port in a different shape, and positon doesn't matter as long as it doesn't cause standing wave pipe behavior.
Corner loading works at bass frequencies several feet away from the apex, so a port on the front of a corner-loaded speaker will act the same as one on the back unless the speaker is several feet deep.
When a sound source is placed at the apex of a trihedral corner, it radiates purely into eighth-space. The walls of the corner define the radiating angle. In this situation, the walls don't act as reflectors because a wavefront travels along them or away from them rather than towards them and reflected by them.
When a sound source is near a boundary, then it confines the radiating area and also acts as a reflector. At low frequencies, where the distance to the boundary is less than 1/4λ, the boundary constrains the radiating angle without any anomalies in frequency response. Above 1/4λ distance, the boundary begins to act as a reflector and peaks and dips will occur at 1/4λ multiples.
The end result of all this is that woofers and ports can be placed fairly far away from corners and still radiate into eighth-space.
Previous Topic: What do you make of this "white paper"?
Next Topic: 7pi mid-horn
Current Time: Thu Nov 05 19:22:16 CST 2026
