Home » Sponsored » Pi Speakers » Midhorn Input Data
Re: Hornresp models [message #50252 is a reply to message #50247] Sun, 12 November 2006 14:11 Go to previous messageGo to previous message
Cuppa Joe is currently offline  Cuppa Joe
Yes, I had played around with expanding the horn in an attempt to move the LF rolloff as close to 160Hz as possible (the highest compromise I'll tolerate for X-over to a dedicated sub), and wound up with a mouth of 30.5" x 15.5", but with only 13" of depth. Shouldn't I need 21.25" of depth for 1/4 WL of 160Hz? The trouble with a 90-degree horn is that the mouth widens 2" for every 1" of depth added.
The rest of the fantasy was to coaxially mount the HF section inside the midhorn's mouth, using a pair of up-ended, trim'n'glue P.Audio PH2510 horns to create an unbroken vertical array to the next midhorn/high pak. Voila, vertical line array!
Previous Topic: mid-horn
Next Topic: Eminence PSD2002 vs JBL 2426h
Current Time: Tue Nov 03 09:05:29 CST 2026
