Home » Sponsored » Pi Speakers » Midhorn Input Data
Re: Hornresp models [message #50247 is a reply to message #50246] Sat, 11 November 2006 23:13 Go to previous messageGo to previous message
The model includes the volume between the cone and the throat, including the spacer. The horn was designed to be used indoors on a cornerhorn, and that's what it was modeled in eighth-space. If you intend to use the horn outdoors, you'll want to model in freespace. Outdoors use requires a much larger horn.
Previous Topic: mid-horn
Next Topic: Eminence PSD2002 vs JBL 2426h
Current Time: Tue Nov 03 07:52:42 CST 2026
