Home » Sponsored » Pi Speakers » 80Hz horn with 2206
Re: 80Hz horn with 2206 [message #50235 is a reply to message #50234] Wed, 08 November 2006 19:27 Go to previous message
Looks pretty good to me. I didn't double check your inputs; I'm assuming you've done that right. The radiation angle is half-space, which is about what you'll have indoors in average sized rooms. If placed near corners or if groups of horns are used, you'll have a little better response. As it is, your horn is flat 90Hz to 400Hz +/-2dB in half-space and I think that's pretty good.
Previous Topic: Gollehon Compression Drivers Needed For 8191 Horns
Next Topic: blue prints
Current Time: Sat Oct 31 08:34:01 CDT 2026
