Home » Sponsored » Pi Speakers » Ordered Stage 4 a few days ago, question on port...
Re: Ordered Stage 4 a few days ago, question on port... [message #50191 is a reply to message #50190] Wed, 25 October 2006 12:58 Go to previous messageGo to previous message
You'll want to tune the box to 38Hz. To do that with a 4" port, I'd make it 6" long. The Helmholtz formula used to calculate this is for a straight (non-flared) port, but the alignment has a lot of "wiggle room" so I wouldn't worry about the flare. In fact, you could safely use a 4" port anywhere from 5" to 7" and the response would be almost the same.
Here's the Helmholtz formula:
Here's a little BASIC program that will calculate the formulas for you:
10 INPUT"Enclosure Volume";VE
20 INPUT"Diameter of Port";PD
30 INPUT"Length of Port";PL
40 VB=VE*1728:PI=3.1415926535:AP=PI*((PD/2)^2):LC=PL+((8*PD)/(3*PI))
50 FR=(13548/(2*PI))*(AP/(VB*LC))^.5
60 PRINT"Fr =";FR;"Hz."
70 GOTO 10
Previous Topic: Oh, Wayne!
Next Topic: Speaker box dimensions
Current Time: Mon Oct 19 16:07:49 CDT 2026
