Home » Sponsored » Pi Speakers » 12Pi
Re: 12Pi [message #50177 is a reply to message #50176] Fri, 20 October 2006 08:19 Go to previous messageGo to previous message
Hornresp is very easy to use. It is also extremely accurate for basshorns. As for the AutoCAD files, I think it is more to do with whether or not you have an AutoCAD viewer. DXF and DWG files can both be used on Macs, and AutoCAD is available on the Macintosh although I don't know if there is a Mac version of the viewer. If so, it can probably be downloaded for free. If you have a PC available, I can send you the Rhino version of the drawing. Rhino has an evaluation version that can be downloaded and used to view the file. It will let you scale and rotate the images and to render them in various ways, including see-through walls and things like that. I'm not sure if Rhino is available for the Macintosh.
Previous Topic: Theater4 Crossover
Next Topic: 2 Pi Tower port diameter.
Current Time: Sun Sep 13 16:38:26 CDT 2026
