Home » Sponsored » Pi Speakers » speaker wire gauge
Re: speaker wire gauge [message #50119 is a reply to message #50117] Tue, 03 October 2006 08:48 Go to previous messageGo to previous message
The power levels you'll be running will make a difference. Typically, at normal listening levels, 16 awg would be adequate. But, if you are using inefficient speakers driven by big amplifiers (high current levels), then the larger awg wire would be best.
Subwoofers often consume a lot of current, hence the 12 awg wire.
Previous Topic: multiple driver manifold for horn loading...
Next Topic: plans 12 horn
Current Time: Wed Sep 30 01:02:26 CDT 2026
