Home » Sponsored » Pi Speakers » Professional Four Questions
Re: Professional Four Questions [message #50043 is a reply to message #50042] Mon, 18 September 2006 14:35 Go to previous messageGo to previous message
The Professional Series four π loudspeaker is a very nice sounding speaker. It works well with many tube amps, having a fairly flat impedance curve and good efficiency. I'll be happy to send you the plans if you tell me your E-mail address.
The Professional Series four π uses a JBL 2226H (8 ohm) and a JBL 2426H or Eminence PSD2002-8 compression driver. The horn is a 90x40 radial design, and the design crosses over where the midwoofer matches horizontal directivity with the tweeter. Best listening area in the vertical is within the 40° pattern of the horn. Much above or below this and upper midrange and treble will suffer.
I'd be happy to sell you the kits minus the woofers, so if that will be helpful, we'll do it. You can also source the parts locally.
The 2241 is an excellent woofer. They work well in a wide range of cabinets, from 4.0ft3 to 16.0ft3 tuned to 30Hz. for subwoofer use, I think 8.0ft3 to 16ft3 is best, and I've built plenty of them that were 10ft3 and they sounded great. So I'd definitely approve of your choice to use a 12.0ft3 box tuned to 30Hz.
Previous Topic: For GARLAND
Next Topic: LAB-12 as HT Subwoofer
Current Time: Sat Nov 07 16:07:13 CST 2026
