Home » Sponsored » Pi Speakers » Premium 4 cabinet modification
Re: Typical Room? [message #49984 is a reply to message #49981] Wed, 06 September 2006 10:22 Go to previous messageGo to previous message
Sounds like your room is pretty live. Plaster walls are much more reflective and provide less damping than drywall on studs with fiberglass behind. You said you have no curtains, just an area rug and I would assume some furniture. So I would expect your your room is pretty reflective.
Is your hardwood floor on a concrete slab? Or is there a crawlspace underneath? If there is a crawlspace underneath, it may resonate at midbass frequencies and the increase in bass might sort of match the increase of mids and treble from having a live room. Hard to say without being there.
When you clap your hands is it sharp? I mean, do you hear wall reflections almost as loud as the direct sound from your hands? If you stomp on the floor does it boom? Does it sound solid like rock or hollow like an empty barrel?
Previous Topic: 9Pi mid-bass horn dimensions???
Next Topic: 2 Pi BR plans, please
Current Time: Sat Oct 17 13:04:20 CDT 2026
