Home » Sponsored » Pi Speakers » Learned some more audio truth outdoors
Re: Learned some more audio truth outdoors [message #49980 is a reply to message #49979] Wed, 06 September 2006 00:34 Go to previous messageGo to previous message
How much do you charge and where will you travel?
Do you use a sweep, discrete sines, white (or pink) noise or a maximum length sequence for your measurements? If a sweep or MLS, how do you synchronize the input capture with the output signal?
How do you decide on the best places to put your speakers?
In any case, might I suggest that measurement microphones placed as an array of points showing response in the listening area might be more useful than the placements of microphones in room corners.
Previous Topic: Bass trapping with corner horns
Next Topic: 9Pi mid-bass horn dimensions???
Current Time: Thu Nov 12 02:59:24 CST 2026
