Home » Sponsored » Pi Speakers » Learned some more audio truth outdoors
Re: Learned some more audio truth outdoors [message #49959 is a reply to message #49954] Tue, 05 September 2006 11:24 Go to previous messageGo to previous message
"The speaker needs to be tested and build for room it's intended to be used."
My design philosophy is to design the speaker to sound right on axis and generate a uniform reverberent field. That makes them sound good just about everywhere. Using this approach, the main thing left is boundary influence, and making speakers designed for corners pretty much sets that. Other models are generally designed to be placed near the wall or corner, for similar reasons.
Previous Topic: Bass trapping with corner horns
Next Topic: 9Pi mid-bass horn dimensions???
Current Time: Sat Oct 17 15:21:01 CDT 2026
