Home » Sponsored » Pi Speakers » Learned some more audio truth outdoors
Re: Learned some more audio truth outdoors [message #49954 is a reply to message #49947] Tue, 05 September 2006 09:59 Go to previous messageGo to previous message
It's been my feeling for a long time that outdoor or chamber testing is good for common ground so one manufacturer can compare to another. It makes the baseline the same. (in theory it should be no effect)
Testing in a chamber or outdoors is no good for building speakers. The speaker needs to be tested and build for room it's intended to be used. a common type of room at the very least. Ideally, custom made for the specific room.
Previous Topic: Bass trapping with corner horns
Next Topic: 9Pi mid-bass horn dimensions???
Current Time: Sat Oct 17 16:31:14 CDT 2026
