Home » Sponsored » Pi Speakers » 16 OHM & 8 OHM
Re: 16 OHM & 8 OHM [message #49893 is a reply to message #49889] Sat, 19 August 2006 22:30 Go to previous message
The driver's impedance is critical since it is a part if the circuit. Generally speaking, you don't use a passive crossover designed for an 8 ohm driver with a 16 ohm driver. It will usually move the crossover point, and since the crossover circuit will also likely be underdamped, there will be a peak in the crossover region.
Here are some links that may be helpful for you:
Previous Topic: Professional Four Pi Plans
Next Topic: Sevin Pro 18 Corner Horn, Hey Wayne!
Current Time: Tue Nov 03 05:03:02 CST 2026
