Home » Sponsored » Pi Speakers » Professional Four Pi Plans
You've got mail! [message #49892 is a reply to message #49888] Sat, 19 August 2006 22:22 Go to previous message
I've sent plans to your Yahoo address. If that's not current, let me know your new address and I'll send them along.
The coil in the woofer circuit interacts with the woofer's voice coil to form a sort of shelved response with attenuation that kicks in at 1kHz. It doesn't really provide 6dB/octave attenuation because the load is inductive rather than resistive. That's why I call it a pseudo-first-order, since there is no Zobel to fix load impedance. But as you've inferred, the woofer's natural rolloff helps out in this regard.
If you move everything down to 800Hz, you may or may not be able to use this arrangement. The woofer won't be rolling off yet, in fact, it's still climbing on axis because of collapsing directivity. You might add a Zobel, see how that works. Or you might go with a higher crossover slope.
Previous Topic: Alpha 10 for mihorn?
Next Topic: 16 OHM & 8 OHM
Current Time: Wed Nov 04 01:14:05 CST 2026
