Home » Sponsored » Pi Speakers » xover
Re: Beta15 in theater 4 box [message #49881 is a reply to message #49879] Thu, 17 August 2006 22:21 Go to previous message
The Theater four π (and seven π bass bin) is a little over 8ft3 and tuned to 25Hz. This cabinet, when used with a Delta 15, gives a response curve somewhere between overdamped and EBS. This is a nice curve for use in rooms with boundary reinforcement, such as against walls or in or near corners.
When substituting the Beta 15 in the same cabinet, response does indeed shift towards being slightly less damped. It develops a slight hump in the midbass. That is a direction you don't want to go in a corner speaker, but I don't think it would sound bad in an open space, pulled away from walls a few feet. But if the cabinet is smaller than 8ft3 - certainly if it is only 5ft3 - the Beta 15 will be too underdamped and will sound boomy no matter where the speaker is placed.
Previous Topic: Heeere's Wayne!
Next Topic: Alpha 10 for mihorn?
Current Time: Thu Nov 19 09:13:23 CST 2026
