Home » Sponsored » Pi Speakers » Some basic questions about Pi web site and speakers:
Re: Intermodulation, phase and Doppler distortion, and then some [message #49855 is a reply to message #49852] Sat, 12 August 2006 01:02 Go to previous messageGo to previous message
Wayne,
I don't agree with the phase shift theory's because you can't hear phase shift unless there's significant time delay's involved,so I don't agree with this:
::a low frequency tone so a higher frequency cone movement must ride upon this shift, which causes a phase shift.
At a certain point the higher frequencies depending what they are, are ethier going to add,subtract or cancel(within the harmonics of the lows, at certain frequencies and x-over points) causing peaks or notches in the overall operating band width of the response.
Isn't this modulating (the highs am style, aka IMD) In a limited bandwith the response with respect to the lows??
This statement I some what agree with:
::The other is a non-linearity caused when the driver is pushed nearing or (not really) exceeding Xmax,
:: where the voice coil has less drive force because it partially "moves out of the gap.(bad news unless your hitting the bottom plate and/or sliding V.C.back into the front of the gap)
This causes it to become non-linear at high drive levels.(TRUE).
Dont, worry because power compression will set in long before hand which will reduce your output 3-7 db because of voice-coil heating. Even though your amps are at full power and not clipping, so don't
boost your lows if you think there lacking.
Time to get off of here,Mr.Seagrams is calling(so I maybe full of s__t)
Not sure though.
Previous Topic: wirewound resistors
Next Topic: Acoustic Suspension Pi and.....ta-daaaa...my new horn
Current Time: Sun Nov 01 12:21:22 CST 2026
