Home » Sponsored » Pi Speakers » The "right" port distance
Re: The "right" port distance [message #49755 is a reply to message #49754] Fri, 21 July 2006 08:34 Go to previous messageGo to previous message
The position of the port in a Helmholtz resonator does not matter. However, in a transmission line it does because its behavior is wavelength related. A bass-reflex speaker is one that uses Helmholtz resonance as the tuning method, but if the cabinet is large enough then standing waves can be an issue. This can be bad, but it can also be used to advantage. You just have to check it and see. I suggest using Martin King's ported box cabinet spreadsheet on any cabinet that is large than a few cubic feet, or one that is tall and thin. If one or more cabinet dimensions is long enough that standing waves might develop in the woofer passband, analysis should be done to ensure no unusual or unexpected response peaks or dips develop.
Previous Topic: Opinions on Eminence Magnum 18LF?
Next Topic: Pushed in Dust Cap
Current Time: Sun Nov 29 09:08:39 CST 2026
