Home » Sponsored » Pi Speakers » Are notches required on 12pi?
Re: Are notches required on 12pi? [message #49722 is a reply to message #49718] Sat, 15 July 2006 17:53 Go to previous message
The router slots are included on the AutoCAD file. It is a perfect drawing, used to generate the CNC cuts. If you'd like, I can send you the drawing I did for the prototype, which didn't have routed edge slots, just screws and glue. It isn't as accurate of a drawing, but is good to the 1/4", which is about as good as you can expect for hand cuts anyway. Works just great.
Previous Topic: 4 Pi Cabinet
Next Topic: Question for FredT re: One-Pi Towers
Current Time: Tue Oct 20 14:53:24 CDT 2026
