Home » Sponsored » Pi Speakers » 4 Pi Cabinet
Re: 4 Pi Cabinet [message #49707 is a reply to message #49705] Wed, 12 July 2006 18:53 Go to previous message
might be fancier, but I've never drilled a countersunk hole from the back for t-bolts. I just mark the holes from the driver with a pencil (circle around and an X marks the spot), move the driver so you don't hurt it or buzz the metal with the side of the bit and have flying shrapnel, drill a hole just slightly smaller than the barrel of the t-nut. then, I use a large o.d. metal washer with a small hole on the front to do the first tighten of the t-bolt and pull the nut into the back by tightening it. You can also tap them with a hammer from the back once they're lined up correctly if you want. They'll pull into the wood very snug with the force.
Previous Topic: Vb vs Damping and Acoustic Absorption
Next Topic: Are notches required on 12pi?
Current Time: Tue Oct 20 10:27:00 CDT 2026
