Home » Sponsored » Pi Speakers » 4 Pi Cabinet
Re: 4 Pi Cabinet [message #49704 is a reply to message #49701] Wed, 12 July 2006 15:29 Go to previous messageGo to previous message
Norbert is currently offline  Norbert
Hi Gar,
Don't worry about not getting back to me sooner... all is well.
You brought up a good point in that the relationship between center of the HF driver and the woofer needs to stay constant (and Wayne confirmed that with all that mathematical calculation -thanks Wayne). What this means is that I need to be carefull when building the enclosure to house the horn. So goodbye to fancy horns such as this ones: http://www.acoustichorn.com/
I ended up using BB-ply from Commonwealth lumber. Getting the 5x5 wood home was quite a challenge... I ended up putting the wood on the roof rack of the van.
To install the T-nuts, do I just drill the hole the size of the cylindrical barrel and let the pressure of the screw drive the prongs into the wood?
Thanks,
Norbert
Previous Topic: Vb vs Damping and Acoustic Absorption
Next Topic: Are notches required on 12pi?
Current Time: Tue Oct 20 12:38:53 CDT 2026
