Home » Sponsored » Pi Speakers » How-to
12π basshorn subwoofer: How-to [message #49664 is a reply to message #49663] Fri, 23 June 2006 23:39 Go to previous messageGo to previous message
You must be talking about the 12π basshorn subwoofer, since it's the only model with plans distributed as an AutoCAD file. See the post called "12π basshorn - Coming together" for a step-by-step pictorial writeup of the construction process. If you want, I can also send out some image files containing the drawing I did of the prototype. It isn't as accurate as the AutoCAD drawing, but it may be useful for you. It is drawn as a side view and it makes it easy to see the dimensions of each part.
Previous Topic: Active Crossover - 4Pi Tower?
Next Topic: Help a newbie! Please?
Current Time: Tue Oct 20 12:38:28 CDT 2026
