Home » Sponsored » Pi Speakers » The shop is crankin' out 12π basshorn subs!
The shop is crankin' out 12π basshorn subs! [message #49629] Wed, 14 June 2006 20:17 Go to previous message
They're really doing great work with these. CNC cut pieces, dado construction, all precision cut and fit. They're impressive and I thought you might want to see a few photos from an inside view.
The 12π prototype was cut by hand and assembled using glue and wood screws. You can see a write-up of the prototype assembly process in the post called "12π basshorn - Coming together". Information about the design is available in the post called "12π basshorn subwoofer". The ones we're making in the shop are from CAD drawings and cut on a CNC, so fitment is perfect. Makes alignment of the pieces much easier too. http://www.audioroundtable.com/emoticons/smiley.gif
http://www.pispeakers.com/Basshorn/12Pi_Side_and_Braces.JPG
Side panel and braces
http://www.pispeakers.com/Basshorn/12Pi_Side_Dado.JPG
Close-up view of motor chamber dado cuts
http://www.pispeakers.com/Basshorn/12Pi_Motor_Panels.JPG
Side panel and motor chamber internal panels
http://www.pispeakers.com/Basshorn/12Pi_Motor_Chamber_CNC.jpg
Motor chamber close-up
http://www.pispeakers.com/Basshorn/12Pi_Fill_CNC.jpg
Front chamber fill pieces
http://www.pispeakers.com/Basshorn/12Pi_Side_CNC.jpg
Side panel
http://www.pispeakers.com/Basshorn/12Pi_Braces_CNC.jpg
Mouth braces, close-up
http://www.pispeakers.com/Basshorn/12Pi_Rear_Open_CNC.jpg
Sides mounted, rear open
http://www.pispeakers.com/Basshorn/12Pi_in_Shop.jpg
Nearly finished, ready for drivers, cooling plugs and panels
http://www.pispeakers.com/Basshorn/12Pi_with_Brad.jpg
Brad examines his work
Previous Topic: Active Crossover - 4Pi Tower?
Next Topic: One Pi Towers in Houston
Current Time: Mon Nov 02 19:10:56 CST 2026
