Home » Sponsored » Pi Speakers » piezos (to DB)
Re: piezos (to DB) [message #49538 is a reply to message #49502] Mon, 29 May 2006 03:04 Go to previous messageGo to previous message
dB is currently offline  dB
Scary... I wouldn't be close (...much less in front of it!). Do you add the highs from the piezo to the highs of the mid-bass or do you have a band-pass xover on the mid-bass? (Do you have?) Attenuation of the piezo with a cap in series, also? Because you might have about 10dBs of a step difference there, unless you make a (xover) smooth transition. Regards
Previous Topic: push-pull - isobarik bass
Next Topic: My new two Pi Studios
Current Time: Tue Nov 03 07:14:02 CST 2026
