Home » Sponsored » Pi Speakers » push-pull - isobarik bass
Re: push-pull - isobarik bass [message #49535 is a reply to message #49532] Sun, 28 May 2006 03:34 Go to previous messageGo to previous message
dB is currently offline  dB
Very nice. Thanks for your explanation Wayne.
Now I have another question.
When I check with WinISD software for a vented box, for a 10" speaker, it gives a nice one with about 80L(2.8cf3) in the 40Hz-1KHz band freq. If I go with isobarik it gives a well developed -- and robust -- frequency response curve with one (box) of only 50L(1.7cf3) in the 30-500Hz band freq.
But the freq. resp. band is now reduced to about 500Hz. What happen to the freq between 500Hz and 1K? Is the electrical output being "spread" by the (two) isobarik speakers so it gives a dim output on the midhighs around 1KHz, and the low's working like a piston develop a better response, like a stronger motor "with twice the strength"?
In this case, if I use the isobarik design, I will have to change the xover frequency from 1KHz to about 500Hz for an even output and nice xover to the lowmids and upper bands(?). Am'I correct? Is the loss in power (500Hz-1KHz) virtually measurable and degraded by such a respectable amount or only approximate?
Best Regards.
Previous Topic: Plans
Next Topic: piezos (to DB)
Current Time: Thu Sep 24 19:30:52 CDT 2026
