Home » Sponsored » Pi Speakers » 2 pi and PiAlign program
Re: 2 pi and PiAlign program [message #49466 is a reply to message #49465] Sun, 14 May 2006 23:23 Go to previous messageGo to previous message
For a woofer like the one you've described (with Qts~0.38), PiAlign generates a recommendation that results in a very good response curve. Woofers with very high Qts values tend towards underdamped response and those with very low Q make slightly overdamped systems. You're is right in the middle so the response curve will be nice and flat. But PiAlign favors small cabinets and you can increase cabinet size and get deeper extension.
Woofers work well in a range of cabinet volumes. For example, I'd expect the woofer you've described to work very well in cabinets from 0.5ft3 to 2.0ft3 tuned to 25-30Hz. If you're going for a full-range speaker with a wide-bandwidth woofer, something like a small two-way speaker, then I'd go with the PiAlign suggestion. But if you are going for a sub, I'd look at alignments that use larger cabinets to get deeper response.
Previous Topic: Corner Horn positioning "Sweet Spot" for listening...HELP
Next Topic: Pi-9 ??
Current Time: Fri Nov 06 07:32:09 CST 2026
