Home » Sponsored » Pi Speakers » Corner Horn positioning "Sweet Spot" for listening...HELP
Re: Corner horns without the triangular baffle [message #49461 is a reply to message #49428] Sun, 14 May 2006 07:30 Go to previous messageGo to previous message
TomM is currently offline  TomM
I installed the rear panels yesterday, and also removed some of the fiberglass stuffing from the midhorns (i had them fully stuffed and wasn't sure I had allowed room for the midhorn to reach as low as it should). The bass, especially the midbass, now has better definition, and overall the sensitivity is noticeably higher. By higher sensitivity the bass is fuller at lower volumes now.
Previous Topic: Cornerhorns for this room?
Next Topic: 2 pi and PiAlign program
Current Time: Thu Nov 19 07:40:52 CST 2026
