Home » Sponsored » Pi Speakers » Cornerhorns for this room?
Re: Cornerhorns for this room? [message #49442 is a reply to message #49439] Sun, 07 May 2006 07:37 Go to previous message
dB is currently offline  dB
Hi riotubes,
After you choose the speakers you have another problem to deal with.
The resonance of your space.
You have a problematic "auditorium", with room modes at the baseline frequencies:
31,7Hz - Width(30.2), Length(32.7)
63,5Hz - Height(66.5), Width(60.4), Length(65.3)
127Hz - bis(132.9), (120.9), (130.6)
Solutions to adress this problem are (as an ex.)1. change room dimensions (not all of them at the-same-time/the-same-way but make one bigger the other smaller or maintain one and change the other), 2. acoustically treat the room, and/or 3. equalize (slide down these freqs to have some control on them - i.e. reverberation or resonance)
(S.Shenefield 1997)
Previous Topic: Suspending Speakers
Next Topic: Corner Horn positioning "Sweet Spot" for listening...HELP
Current Time: Thu Nov 19 08:02:05 CST 2026
