Home » Sponsored » Pi Speakers » Theatre 3 Pi Crossover
Re: Theatre 3 Pi Crossover [message #49424 is a reply to message #49423] Tue, 02 May 2006 09:05 Go to previous message
Sounds good. If you want to try alternate configurations, just use the PCB without the tweeter compensation cable assembly and/or without the Zobel. Hook the drivers up directly to the crossover PCB. Replacing the tweeter compesation cable with a straight cable will let you know how the tweeter sounds without CD EQ. Removing the Zobel will add a peak in response coming from the woofer around the crossover frequency.
Previous Topic: Wayne - Crossover values for 2 x 16-ohm motors in Four-Pi Pro
Next Topic: Server Problem?
Current Time: Thu Nov 19 08:24:26 CST 2026
