Home » Sponsored » Pi Speakers » Corner Horn positioning "Sweet Spot" for listening...HELP
Corner Horn positioning "Sweet Spot" for listening...HELP [message #49390] Thu, 27 April 2006 22:29 Go to previous message
Ed White is currently offline  Ed White
I'm nearing completion of my Theater Seven Pi corner speakers, and I'm wondering about positioning in my listening room.
The room is aproximately 14 by 18. Do I position the speakers on the shorter wall, and have the "Throne" at a direct 45 degree angle from each speaker? Does it matter if I sit further back from this "convergence point"? If I put them in the corners on the long side of the room, the 45 degrees from each one aproximately coincides with a seat in the middle of the opposite wall. If it's the other way, it's more in the middle of the room. Any Suggestions?? I know you'd never place conventional speakers this far apart, but they stick out quite aways from the corners.
Ed White
Previous Topic: Cornerhorns for this room?
Next Topic: 2 pi and PiAlign program
Current Time: Thu Nov 19 07:41:10 CST 2026
