Home » Sponsored » Pi Speakers » Compensation circuit when using active crossover
Re: Compensation circuit when using active crossover [message #49191 is a reply to message #49188] Mon, 27 March 2006 11:26 Go to previous messageGo to previous message
If your crossover has no options, then you'll have to provide your own EQ. The curve you want has a pretty simple shape, a flat shelf from the crossover point up to 4kHz and then rising response after that.
If you don't have an equalizer, you could use a series resistor and bypass cap in line at the preamp level. That will give you the rising response part of the curve. It won't provide the flat shelf from crossover up to 4kHz, but it is a simple circuit that would be better than no compensation at all.
Previous Topic: Parts Express 3.0 cu ft subwoofer cabinet
Next Topic: mid-horn
Current Time: Fri Oct 02 03:01:24 CDT 2026
