Home » Sponsored » Pi Speakers » Stage 4Pi improvement
| Understandable Results [message #49030 is a reply to message #49007] |
Mon, 06 March 2006 13:35  |
FredT
Messages: 704 Registered: May 2009
Illuminati (1st Degree) |
My 3 Pi's sounded very live to me with 3/4" mdf as the enclosure material and a single window frame brace between the woofer and tweeter. I subsequently lined the interior with 3/8" plywood panels attached with a generous layer of liquid nails, and this tamed quite a bit of the boominess. I suspect the culprit was the vibration in the enclosure walls, which I could easily feel by holding my hand on a panel while playing a recording with strong bass content. Adding the plywood panels did compromise the interior volume a bit, but the overall result was worth it. The 1-1/4" sonic barrier that LAL used is a multi constrained layer damping material which I would expect to make a difference if the speaker's liveliness is caused by the panels ringing.
By: LAL on Sat, 04 March 2006 10:39
Re: Stage 4Pi improvement
By: Pfenning on Sat, 04 March 2006 11:10
By: LAL on Sat, 04 March 2006 14:18
By: Matts on Sat, 04 March 2006 21:50
By: LAL on Sun, 05 March 2006 10:23
Re: No offense, Matts, but
By: Matts on Sun, 05 March 2006 13:06
By: LAL on Sun, 05 March 2006 19:44
By: Matts on Sun, 05 March 2006 21:02
By: LAL on Sun, 05 March 2006 21:22
** TRUE SONICS **
Earplugs
By: dB on Tue, 07 March 2006 05:43
Re: First order x-over
By: dB on Wed, 08 March 2006 07:37
By: Matts on Sun, 05 March 2006 21:06
By: GarMan on Mon, 06 March 2006 08:54
By: ToFo on Mon, 06 March 2006 13:17
By: LAL on Tue, 07 March 2006 14:32
By: GarMan on Wed, 08 March 2006 07:30
By: FredT on Mon, 06 March 2006 13:35
Current Time: Thu Nov 05 22:00:51 CST 2026
