Home » Sponsored » Pi Speakers » Stage 4Pi improvement
Re: Stage 4Pi improvement [message #49025 is a reply to message #49007] Mon, 06 March 2006 08:54 Go to previous messageGo to previous message
Hey LAL. Thanks for the report. I noticed that your cabinets were lined live-side/dead-side with fibreglass, but pretty much all around with Sonic Barrier. No doubt, the resulting improvements were probbably a combination of different material and placement. I'd be interested in knowing how much of it was gained with material vs placement (ie. would you get the same results if five sides were lined with fibreglass). Unfortunately, it sounds like it's impossible for you to remove the Sonic Barrier to test.
Also, was there a reason why "Glop" was originally only used on the unlined sides? Fibreglass does a good job of absorbing soundwaves but not much to dampen panels. I've found that putting some type of Glop-like material on all internal walls before lining with absorbant works very well to reduce boom.
Gar.
Previous Topic: FredT's looked so good and Shane complained, so...
Next Topic: The MOST SUB - Just for fun
Current Time: Thu Nov 05 22:01:53 CST 2026
