Home » Sponsored » Pi Speakers » the begin
Re: Sweet! [message #49000 is a reply to message #48998] Fri, 03 March 2006 05:39 Go to previous messageGo to previous message
dB is currently offline  dB
In my white speaker image you can find for the bass a 12" HH Acoustics DC100LW, 2” voice coil and magnesium alloy chassis, 100W Fs=60Hz 99dBSPL (50-13000Hz Wide Range P.A., Monitor, Disco). This bass horn is a modified two side exponential horn with a mouth diameter (equivalent circle) of 22"(55.5cm) or 26.4"(67cm) x 14.2"(36cm)square. Mid is a compression driver Beyma AL-CP40, 1.75” voice coil, 60W 108dBSPL (800-7000Hz). HF compression tweeter is a Beyma CP10 w/mylar diaphragm and aluminium voice coil support, 10W 105dBSPL (5000-20000Hz). X-over is a from same factory of the shelf not tested but taken for good one day will see high power good components crossover.
On the Disco speaker images you can notice two JBL 2405H Ultra-highs (or similar) on the right of the speaker and a super-duper acoustical lens (slant-plate type) spread on top. Besides the 4 mains there are 2 more subs. But I didn’t find an increase in quality output when they bought them. I don’t know the factors or specs for all the set-up.
Regards
Previous Topic: Wayne
Next Topic: Superlux ECM-999 or Behringer ECM-8000 for Measurement
Current Time: Fri Nov 06 00:46:44 CST 2026
