Home » Sponsored » Pi Speakers » Corner horns with no corners?
Re: Wings with hinges or rollers [message #48901 is a reply to message #48875] Fri, 17 February 2006 20:23 Go to previous message
dB is currently offline  dB
Hi Shane,
I just found (and remember on how to do it) this nice idea on this site in France PHY-HP ‘haut parleurs’. They have speakers that are beautiful works of art in bronze and a … sand baffle with piano hinges for the open baffle configuration.
Check it out: (www.phy-hp.com/Communication/Com_Baffle_Plan_Impr.html). You can move your wings with hinges accordingly… If you need to move you just take out the sand.
...or rollers...
(www.zenn.com.sg/Solid_35kg_stds.JPG)
…another one…
(http://arolio.free.fr/hifi/hifi3.html)
Best Regards
Previous Topic: Theater 4 or 7 plans?
Next Topic: Le (T/S)
Current Time: Fri Oct 23 16:47:11 CDT 2026
