Home » Audio » LSAF » LSAF 2008 - Show Coverage, Seminar Recordings, Slideshows and Handouts
Re: Axisymmetrical horns [message #4886 is a reply to message #4883] Tue, 20 May 2008 16:12 Go to previous messageGo to previous message
Good point - I hadn't thought of that.
Another advantage of a rectangular horn is that you can go to a TMM (or would that be HWW?) format and get vertical as well as horizontal symmetry. I tried modelling symmetrical MTM (WHW?) cnofigurations but unless the crossover is quite low (or the horn too narrow in the vertical plane to maintain reasonable pattern control) the woofers end up too far apart and their vertical lobe is too narrow, in my opinion. Of course you'll still have the inevitable vertical pattern "pinch" at the crossover frequency.
Have you done any dual-woofer speakers? I don't recall seeing any, but then presumably not everything that happens in the lah-BORE-ah-TORE-ee enters your product line-up.
By the way, best of luck with your heat-pipe patent!
Duke
Previous Topic: LSAF 2008 Pictures
Next Topic: Dagogo coverage of LSAF
Current Time: Fri Oct 16 19:17:44 CDT 2026
