Home » Audio » General » White Lightning ICs
Re: Upon further review [message #4884 is a reply to message #4882] Mon, 19 May 2008 15:11 Go to previous message
How about covering the too-easy-to-melt insulation with a sleeve of teflon, of correct diameter? You solder the shield connection first, right? Then you could even wrap it in teflon tape for a bit better heat and insulation, maybe.
Previous Topic: Slide show
Next Topic: Lone Star Bottleheads - Houston, May 31st
Current Time: Fri Nov 27 06:02:22 CST 2026
