Home » Audio » General » White Lightning ICs
Re: Upon further review [message #4882 is a reply to message #4879] Sat, 17 May 2008 19:59 Go to previous messageGo to previous message
One of the most recent pair, which tested perfect, shorted. Sure enough, the thin shield was touching the hot pin.
I went back to placing shrink tube over the hot pin and a 1/4" or so of the hot wire.
I also revisited the crimp and solder, magnifying the pic Jeff Day took for his review.
As you can see, especially if you enlarge with MS My Pictures, one barrel crimp is pressed down and then the neutral is sandwiched between it and the other. This may be a better method of making a good mechanical connection while still protecting the hot wire from the iron heat.
I'm kinda obssessing because my previous fave connectors were vampire 800C, $27/pr and Eichmann at $44/ set of 4. The Switchcraft have gone up, BTW, ten piecees will now set you back $18.80.
Previous Topic: Slide show
Next Topic: Lone Star Bottleheads - Houston, May 31st
Current Time: Tue Oct 13 19:20:06 CDT 2026
