Home » Sponsored » Pi Speakers » Super-tweeter, super-image, super-sound
| Eminence ASD 1001 [message #48792 is a reply to message #48790] |
Fri, 03 February 2006 14:22   |
FredT
Messages: 704 Registered: May 2009
Illuminati (1st Degree) |
I hesitate to comment since I have never heard it, but its frequency response curve reminds me of the $30 Selenium DH200E, which I once compared directly to the Eminence PSD 2002 sitting atop the 3 Pi's. Using the standard 3 Pi crossover I found the treble response dropped very sharply with increasing frequency, so much so that it sounded like there was no "presence" with the Selenium. I notice the Eminence 1001 has the same kind of drop between 3.5 and 10khz. The 2002 is a bit pricey in comparison (all good compression drivers are), but it carries all the information above 1,500khz in the 3 Pi, and I would be concerned it might not sound very good. Compare the freq response graphs on the mfg spec sheets for the 1001 and the 2002. The 2002 has a dip too, but the capacitor that parallels the series resistor in the L pad does a reasonably good job of compensating. I doubt it would for the 1001.
Re: Super-tweeter, super-image, super-sound
By: Shane on Sat, 28 January 2006 21:18
Re: Full Vifa line-up at Madisound
Thanks For The Idea
By: FredT on Tue, 31 January 2006 15:39
Supertweeter Picture
By: FredT on Fri, 03 February 2006 11:43
Theater three π
Re: Theater three π
By: FredT on Fri, 03 February 2006 14:11
Re: Theater three π
Re: Supertweeter Picture
Eminence ASD 1001
By: FredT on Fri, 03 February 2006 14:22
Re: Eminence ASD 1001
By: FredT on Fri, 03 February 2006 14:28
Final Picture
By: FredT on Mon, 06 February 2006 11:48
Re: Final Picture
Re: Final Picture
Current Time: Thu Nov 19 13:06:13 CST 2026
