Home » Sponsored » Pi Speakers » SPICE parameters
Re: SPICE parameters [message #48787 is a reply to message #48785] Fri, 03 February 2006 12:25 Go to previous message
I think it will probably work just fine. In this case, you'll be measuring impedance. The sensitivity of the speaker won't affect your tests. The main thing is the accuracy of the meter at different frequencies. Hand-held multimeters didn't do such a good job at measuring AC outside of a narrow range in the past, because they were really designed only for AC line voltage. But all the DVM's I've seen lately are pretty accurate across the audio band, at least the frequencies of interest for a test like this (bass to midbass). Be sure to get an accurate measurement of your test resistor, because it will set the reference.
Previous Topic: Check out this woofer
Next Topic: 7pi-18 Audiophile plans
Current Time: Tue Nov 03 11:28:17 CST 2026
