Home » Audio » LSAF » LSAF 2008 - Show Coverage, Seminar Recordings, Slideshows and Handouts
Axisymmetrical horns [message #4877 is a reply to message #4873] Sat, 17 May 2008 02:11 Go to previous messageGo to previous message
I really thought your speakers sounded nice. All the rest of this is academic. But in the pursuit of the best sound we can make, please don't be offended if I make an observation, a question about one of your design choices, really.
The one thing that always puzzled me is why you chose a round tweeter horn. I remember talking to Earl about his choice to go axisymmetric on the Summas too, when he could have chosen to use an asymmetrical prolate spheroidal flare instead. That shape is in the same family that he likes so much, with the throat radiused like the oblate spheroidal horn in the Summas.
I think you both use 90° axisymmetrical horns and a crossover around 1kHz. They're about 12" diameter, as I recall, so the center-to-center spacing from woofer to tweeter must be about 15" or so. With those general dimensions, I would expect lobes at around 25° above and below the forward axis. In that case, it seems to me it would be better to use a horn with 50° vertical pattern.
Why use a 90° round tweeter horn? Do you really want the tweeter pattern to be taller than the lobe angle?
Previous Topic: LSAF 2008 Pictures
Next Topic: Dagogo coverage of LSAF
Current Time: Tue Sep 29 15:42:22 CDT 2026
