Home » Sponsored » Pi Speakers » 2 Pi Towers with PSD2002 crossed over at 1.6Khz
Re: 2 Pi Towers with PSD2002 crossed over at 1.6Khz [message #48675 is a reply to message #48668] Tue, 24 January 2006 07:04 Go to previous messageGo to previous message
Hello Hakn,
I did the exact same mod a couple of years ago. Called it my version of the "Thermionic-2". Great sound. More refined and controlled. Loss a bit of "liveliness" though. I think one of the things that make the Studio-2's sound so great is the simplicity of its crossover. Somewhere between zero and first order.
I've since put this set up away and moved to the Theatre-3, so I can't have you the compensation network values. Wayne's crossover document should give you the values though
What horns are you using with the 2446? I had 2380A's on my 2445 for a while, but found my DIY smith horns to sound nicer. Less edgy at high volume and larger sweet-spot.
gar.
Previous Topic: mid-horn
Next Topic: two questions Wayne.
Current Time: Sun Nov 01 12:20:58 CST 2026
