Home » Sponsored » Pi Speakers » Is mixing 'n matching cabs a bad idea ?
Is mixing 'n matching cabs a bad idea ? [message #48601] Fri, 13 January 2006 04:19 Go to previous message
pieter is currently offline  pieter
Hope this is the right forum, I'm looking for some open minded speaker and cab geeks.....
I'm looking for a 2nd cab for my bassguitar playing. My first cab is a 1x12 + tweeter. As a whole, that cab is full range. It is 8 ohms.
I'm looking for a second 8 ohm cab.
Some guys buy (or build) an identical cab, so that they have two 1x12 cabs. The second cab can be without a tweeter. They say: the two cabs must be identical, otherways the lows will never be tight.
Other guys like to add a 10". So, they have a 1x12 + 1x10. Or even a 1x12 + a 2x10. Or, they add a different 1x12 (so, they use two different 12" drivers). Usually, no cross overs are used between the cabs, so both cabs run full range.
These guys say: the second cab should be different, to compensate for the weak points of the first cab. For instance, if the first cab has a strong bass but shy mids, they like to add a cab with a lean bass and strong mids.
My question: who is right? Must the cabs be identical, to prevent "mud", or can the cabs be different, so that they complement each other ?
Second (related) question: if one uses different cabs with overlapping frequencies, MUST one use a crossover? Why? What cross over?
Thanks in advance,
Pieter
Previous Topic: Two pi and Tower two ~ Xover and plans
Next Topic: Anybody with plans and circuit for 12" based 3 ways?
Current Time: Sun Nov 01 12:20:50 CST 2026
