Home » Sponsored » Pi Speakers » TAD TD-4001 Passive Crossover Suggestions Wanted!
Re: TAD TD-4001 Passive Crossover Suggestions Wanted! [message #48592 is a reply to message #48590] Thu, 12 January 2006 12:33 Go to previous messageGo to previous message
spkrman57
Use Wayne's 800hz crossover and use the attenuation that gives the same efficiency for both drivers.
Even though you are using a 2" compression driver 800hz is a better crossover point than 500hz/600hz due to the vocals being projected better and it is safer for the compression driver.
I use GP's 399 driver 1.4" and even though it is rated down to 500hz it projects a sweeter sound at 800hz!
Hope this helps.
Ron
Previous Topic: mid horn box size?
Next Topic: 6 pi plans
Current Time: Thu Nov 26 05:55:44 CST 2026
