Home » Sponsored » Pi Speakers » TAD TD-4001 Passive Crossover Suggestions Wanted!
TAD TD-4001 Passive Crossover Suggestions Wanted! [message #48590] Thu, 12 January 2006 12:08 Go to previous message
Mikey is currently offline  Mikey
Hi All!
My next loudspeaker project is a two-way design, utilizing a TAD TD-4001 compression driver and a TAD TL-1601A woofer.
The target crossover frequency will be in the 500-650Hz range. In the interim, I'll be using a pair of JBL 2380A horns; but I plan on
eventually replacing them with some wooden horns....maybe TH-4001's (if I win the lottery!), or Edgar salad bowls, or ???
Does anyone have any experience with a simple passive crossover to run the 4001's? Unfortunately, bi-amping is out of the question,
at least in the near future.
Also, horn suggestions would be welcome too. What have you guys tried (and liked) in your home environment?
Wayne, have you got a 'tried and true' crossover that you've designed for these drivers?
Thanks in advance,
Mike
Previous Topic: mid horn box size?
Next Topic: 6 pi plans
Current Time: Wed Nov 04 16:34:54 CST 2026
