Home » Sponsored » Pi Speakers » Pre Compensation Load on X-OVERS and L-Pads
Re: Pre Compensation Load on X-OVERS and L-Pads [message #48576 is a reply to message #48542] Tue, 10 January 2006 17:04 Go to previous messageGo to previous message
dB is currently offline  dB
Dear Mr. (Wayne) Parham,
Hi. It his a pleasure to be able to ask you a question and having you ‘in person’ to answer to them. First I am learning how to work with Spice software and what a difference from 20 years ago with/when my only book (that) was >PHILIPS Building Hi-Fi Speaker Systems. Thanks to all of you guys from Berkeley. I am making such great improvements that I feel pity that I am only an unemployed architect and not a technologist engineer to find a job in this area. It seems that now everybody has a position open for engineers. At least I have time for what I like and what I can do…
Second I wanted to take in consideration that how more times I read your paper ‘Speaker motors and passive crossover filters’ there is something that doesn’t add up. Since my first question that I couldn’t find an answer.
1. On page 33 you show:
R1 3 1 5.5
R12 1 0 3.7
If the speaker is 1 – 0 your R1 should be 3 – 0 (not 3 – 1) and R12 3 – 1 and not 1 – 0. (Or Spice is right and the drawing is wrong?)
2. Again on page 35 you show:
L2 5 6 0.6mH
C2 5 3 16Uf
R1 3 1 5.5
R12 1 0 3.7
C1 3 1 5uF
If the speaker is 1 – 0, R1=> 3 – 0, R12=> should be 3 – 1 (from C2-1.st order?) and not 1 – 0. (Or the drawing is not right…)
What is confusing me is that the Pre-compensation can be connected to 1 (Motor-Speaker) or to 3 (C2 from 1.st order x-over).
Again on page 37 and page 52:
! series/parallel compensation
R1 3 1 25
R12 1 0 16
C1 3 1 0.47uF
If you noticed R1 IS OK, C1 IS OK AND R2 IS WRONG AGAIN.
Should it be R2 1 – 0 ? Or R2 3 – 0 ? With L1 from 2nd order x-over. All connections from Spice seem to be right and the x-overs drawings wrong.
If L1 is 1 – 0 (page 51) then, when you introduce a !series parallel compensation on the circuit (from page 52) 1 becomes, then, 3 from C2 (C2 => 5 – 3), C1 =>3 – 1 AND R1=> 3 – 1 (Speaker 1 – 0).
R2 is then 1 – 0 (parallel with the speaker 1 – 0). But the drawing is not showing that. What it’s showing is R2 (from)3 –(to)0 (in series with C2 (of 2nd order x-over) .
Thanks again Mr. Wayne and thank you for your time.
Best Regards
From da Bastos
Previous Topic: 7pi
Next Topic: Pro Pi4 plans please.
Current Time: Sun Nov 01 14:43:12 CST 2026
