Home » Sponsored » Pi Speakers » Seven pi corner
Re: Yes, and the pros and cons please. [message #48574 is a reply to message #48573] Tue, 10 January 2006 12:41 Go to previous messageGo to previous message
The benefits of the π cornerhorn include constant directivity and a wide sweet spot in addition to all the other advantages of horn loading, i.e. increased efficiency, reduced distortion, etc. The sound source comes from a single location - the apex of the room corner - and the coverage angle is a constant 90° for the entire audio range. Each horn (low, mid, high) has this pattern so the reverberent field is highly uniform. Corner placement makes each horn radiate into constrained space, which makes their response curves smoother than any other location. Early reflections from sidewalls, floor and ceiling are reduced yet room coverage is very good. The only drawback is that placement is limited to room corners. But if you have the corners available, use them.
Previous Topic: Anybody with plans and circuit for 12" based 3 ways?
Next Topic: speaker advice
Current Time: Sun Nov 01 11:13:43 CST 2026
