Home » Sponsored » Pi Speakers » 2500 hz hump
Re: 2500 hz hump [message #48391 is a reply to message #48390] Wed, 14 December 2005 08:25 Go to previous messageGo to previous message
There are a couple of things that cause midrange response to rise in a midwoofer. One is collapsing directivity and the other is cone flex resonance, modes where the cone is twisting and a resonance sets up on the membrane. Collapsing DI causes a flat line of rising response but resonance modes cause peaks. You can equalize collapsing DI in the crossover, and it is a useful feature when paired with a HF horn, because you can crossover in the frequency range where directivity is similar between the two subsystems. Breakup modes are a little trickier to work with, because they make the driver surface act a sort of like a chaotic array of sound sources that change with respect to frequency.
Previous Topic: 2 Pi volume
Next Topic: Help....My Girlfriend Needs as Professional!
Current Time: Sat Oct 31 20:17:09 CDT 2026
