Home » Sponsored » Pi Speakers » Two Tower initial impressions
Re: Two Tower initial impressions [message #48278 is a reply to message #48265] Mon, 21 November 2005 19:19 Go to previous messageGo to previous message
Norbert is currently offline  Norbert
I started using carpenter's glue... that didn't go well because I only have four clamps and a big piece of plywood to sandwich the veneer and I am certain I needed more... so for the rest of the project I used contact cement.. all of my bubles came after applying latex shallac over contact cement backed veneer. Speaking of veneer, I used the raw variety. Looking back I'll never use raw veneer again (although it was way cheaper compared to paper backed ones) and would need way more clamps... someone told me later that I also needed a roller to apply on the veneer when matting to the clued surface.
Bill, would you have any other suggestions?
Previous Topic: request for 2 pi bass reflex plans
Next Topic: Request for wooden HF horn plans
Current Time: Mon Nov 02 17:27:38 CST 2026
