Home » Sponsored » Pi Speakers » Two Tower initial impressions
Re: Two Tower initial impressions [message #48258 is a reply to message #48252] Sun, 20 November 2005 09:19 Go to previous messageGo to previous message
Norbert is currently offline  Norbert
Shane, I can believe it...speaker placement is another variable that can change the sound coming out of the speakers. Have you tried placing the speakers near a corner? I am quite sure it will futher increase bass coming out of the speakers.
When you are ready to veneer your speakers, I would suggest that you do lots of research and seek experienced help, if you haven't done it before...Speaking from personal experience, my veneering job was the only part of my speaker project that gave me some grief. If you plan on veneering the back and bottom of your speakers (I spray painted the back and bottom of my speakers)you may want to start with that first to gain some experience, including staining/shallacing... What may turn out to be a good veneering job can be nulled when the stain is applied such as in my case - I started to see air bubbles coming out of the veneer. It is ok now and no one can tell sitting 5, 10 feet away. I still enjoy the sound and that is all that matters. Cheers.
Previous Topic: request for 2 pi bass reflex plans
Next Topic: Request for wooden HF horn plans
Current Time: Mon Nov 02 16:10:51 CST 2026
